Use this procedure to configure global custom option data for DHCP Server. Unless you
create a subnet-specific configuration, subnets inherit the global configuration.
You must first configure Custom Option Definitions. For more information, see Configure Custom Option Definitions for the DHCP Server.
- Select DHCP Server.
- Select the Custom Option Data tab.
- Select Insert.
- In ID, type the DHCP code that you defined for the option.
- In Value, type the data value to assign to the option.
- Select Insert.
Custom Option Data Field Descriptions
Use the data in the following table to use the Custom Option Data tab.
| Name | Description |
| ID | Specifies the DHCP code that identifies this Custom Option. Must be an integer in the range from 224 to 254. |
| Value | Assigns a data value to this Custom Option. The value must use the data type format that is specified in the Custom Option definition. |
